Posts: 23   Pages: 3   [ 1 2 3 | Next Page ]
Previous Thread This topic has been viewed 21389 times and has 22 replies Next Thread
AnonDMV
Problem Starting Online Version
When trying to start the online version, I get the following error: ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet.
Don't see this in the FAQ or another thread. Runing IE9 with Java 10.7.2. Thanks for any help.
[Mar 8, 2013, 5:16:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problem Starting Online Version
Do you get this error when you try to run the Online version at this page, or when you try to run your own version.
[Mar 9, 2013, 3:12:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AnonDMV
I get the error when trying to run the Online version at "this page" (http://www.sweethome3d.com/SweetHome3DOnline.jsp). I have not attempted to install or use a download version. Thanks.
[Mar 14, 2013, 4:07:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
StNff
I Do get this error when I try to run my own version. And another question. In what directory should I have catalogs of furniture and textures?
[Mar 16, 2013, 12:55:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
StNff
P.S. ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DViever
[Mar 17, 2013, 5:51:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
StNff, I don't understand why you report an issue with com.eteks.sweethome3d.applet.SweetHome3DViewer in a subject about the Online version (i.e. com.eteks.sweethome3d.applet.SweetHome3DApplet class). What are you trying to do?
[Mar 18, 2013, 7:58:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
StNff
<font><font class=""> Re: Проблема Начиная Электронная версия </font></font>
I have compiled applet (ANT utility). I have this error when trying to start SweetHome3DApplet.html.
http://osnova-mebel.com/3d/SweetHome3DApplet.html
[Mar 18, 2013, 12:58:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
StNff
confused Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font>
P.S.
I have the error ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet.
I think I had another error yesterday.
[Mar 18, 2013, 3:49:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
StNff
I had JDK 7.
Now I have JDK 5 (As in the instructions).
Log compilation:
D:\1>ant javaWebStart
Buildfile: D:\1\build.xml
build:
[mkdir] Created dir: D:\1\build\classes
[javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
alse for repeatable builds
[javac] Compiling 2 source files to D:\1\build\classes
[javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
[javac] Compiling 193 source files to D:\1\build\classes
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[copy] Copying 261 files to D:\1\build\classes
[zip] Building zip: D:\1\build\SweetHome3D.jar
[delete] Deleting directory D:\1\build\classes
application:
[zip] Building zip: D:\1\build\SweetHome3DStandalone.jar
[move] Moving 1 file to D:\1\build
furniture:
[zip] Building zip: D:\1\build\Furniture.jar
textures:
[zip] Building zip: D:\1\build\Textures.jar
help:
[zip] Building zip: D:\1\build\Help.jar
jogl-java3d:
[zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar
java3dLibraries:
[mkdir] Created dir: D:\1\deploy\lib\windows\i386
[zip] Building zip: D:\1\deploy\lib\windows\i386\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\windows\x64
[zip] Building zip: D:\1\deploy\lib\windows\x64\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\linux\i386
[zip] Building zip: D:\1\deploy\lib\linux\i386\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\linux\x64
[zip] Building zip: D:\1\deploy\lib\linux\x64\java3d.jar
[mkdir] Created dir: D:\1\deploy\lib\macosx
[zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar
javaWebStart:
[mkdir] Created dir: D:\1\build\JNLP-INF
[copy] Copying 1 file to D:\1\build\JNLP-INF
[zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar
[zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar
[copy] Copying 6 files to D:\1\deploy\lib
[input] Enter Passphrase for keystore:
1111
[signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D
[signjar] jarsigner error: java.lang.RuntimeException: keystore load: D:\1\keys.keytool (═х єфрхЄё  эрщЄш єърчрээ√щ Їр
щы)
BUILD FAILED
D:\1\build.xml:238: jarsigner returned: 1
Total time: 1 minute 40 seconds
Tell me, what's the problem?
[Mar 24, 2013, 11:50:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Reading the README.TXT file coming with the source file would have given you the answer:
Note that the last part of the Ant targets javaWebStart, applet and viewer requires a passphrase for keystore to sign the deployed jars. For security reasons, the required file keys.keytool isn't provided with this source code. You'll have first to generate this file and choose a passphrase, with the following command run in the directory where you uncompressed this archive:
keytool -genkey -keystore keys.keytool -alias SweetHome3D
[Mar 24, 2013, 1:39:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
