Total posts in this thread: 5
Previous Thread This topic has been viewed 4677 times and has 4 replies Next Thread
cristeab
Inserting objects at specified location in a building plan
Hi
Is there a way to insert (manually or programatically) new objects at a given position on a building plan ? I would like to be able to specify object position in cartezian coordonates (x,y,z) and to insert or remove this object in a building plan from my own program using an API.
thanks
Bogdan
[Feb 1, 2013, 7:47:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Inserting objects at specified location in a building plan
HomePieceOfFurniture instances can be moved with their setX, setY and setElevation methods. But why programming something you can already do with the existing user interface?
[Feb 5, 2013, 7:37:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cristeab
I would like to use Sweet Home 3D for object tracking inside a building.
[Feb 5, 2013, 8:24:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Then call the methods of HomePieceOfFurniture. The listeners that are already added to a piece will automatically update its location at screen if necessary.
[Feb 5, 2013, 8:32:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cristeab
Could you please provide an example of programmatically inserting and moving an object on the building plan ?
[Feb 5, 2013, 8:59:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
