Total posts in this thread: 2
Previous Thread This topic has been viewed 3146 times and has 1 reply Next Thread
Lumaja
South Africa
Help on making walls
Making a plan of my house from a drawing of the house to make alterations has the outside walls dimensions, use this dimensions to make this plan but things went wrong.
Made this plan with “tooltip” entering correct dimension wall sizes, I start on wall (top left) A=10.5 to the right
and ending on wall F=8.50, front left bottom to left top I see the this wall doesn’t met the beginning of the first correctly and when measuring the outside dimension are all wrong or not the same that I entered
Can you please help me how to do correct.
Thank you
[Dec 17, 2012, 12:59:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Help on making walls
Luis,
The length of walls is measured at their center, not at the inside or outside.
So, a room of 400x400 cms with walls of 20 cms thick, should be drawn with walls of 420 cms.
[Dec 17, 2012, 2:35:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
