Total posts in this thread: 137
Posts: 137   Pages: 14   [ Previous Page | 2 3 4 5 6 7 8 9 10 11 | Next Page ]
Previous Thread This topic has been viewed 262494 times and has 136 replies Next Thread
mrszekely
Magyarország
Re: Sweet Home 3D 4.0
One more thing...when i made a lot of points of view is there any option for delete the old ones?Is that possible?
Intel Core i7-2630QM 2.00GHz-8GB RAM-nVidia Geforce GT555M with CUDA-Windows 7 64bit
[Feb 10, 2013, 10:55:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks Márton for your feedback. It's not possible to delete points of view at this time.
I could easily add a menu item to remove all of them, but removing them individually would be more complicate. I'll see if I can do something in the next version though.
[Feb 10, 2013, 12:18:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
robal
An option to do that would be nice indeed.
As a workaround, you can set any POV's name to the same name as one of the other POV's. It will overwrite the old one.
[Feb 10, 2013, 11:14:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mrszekely
Magyarország
Thanks for your feedback guys!
[Feb 11, 2013, 9:32:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mrszekely
Magyarország
Could be the render status picture bigger(in create POV)?
Same as on the normal render?
Might be better.Thnak you.
Sorry for my quick posts, it's beacuse i'm working on a project.
[Feb 11, 2013, 1:19:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mrszekely
Magyarország
Hi guys again!
I've found a new intresting thing...
Last night i left my computer to render 6 full HD image.I've started the create photos from POV, but the CPU's cores didn't reach the 100% of usage.They jump between 20% to 60%.
In the morning i saw the render process not finished.
But if I start the last stable version (3.7) from jar file (i made the memory tuning from the FAQ) it's using the cores at 100% and the render process is faster.
Any idea?
Thank you!
[Feb 12, 2013, 8:19:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Here's the Beta 14 with the following new features and bug fixes:
- The color chooser was greatly Improved with different color palettes, a pipette tool and a list showing the recently chosen colors (saved in user preferences):
- A new Libraries button was added to About dialog box to display all the libraries and plug-ins used by Sweet Home 3D in a new dialog box:
- The 3D view > Delete points of view menu item was added to select and delete some of the points of view stored in home.
- Handling clicks on web links shown in the help and about dialog box is fixed thanks to the call to xdg-open command under Linux.
Please, check that the pipette works correctly on your side, because making it work required a few hacks. It's not perfect but globally it works correctly under Java 6 and 7, Windows / Mac OS X / Linux in my case.
These should be the last new features for version 4.0, and it's now time for translation! smile
There should be a few adjustments and bug fixes before the final release, but no change that would require new words to be displayed (and translated) in the user interface.
[Feb 12, 2013, 5:00:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I need some help from users running Sweet Home 3D beta version from behind a proxy server. I wanted to test it myself but installing a temporary proxy for test purpose on the machine you use daily seems not so simple. sad
If you know you use a proxy for http protocol, please check that the following message is displayed when you run Sweet Home 3D Beta from its Java Web Start link and from a Jar executable file (simply double click on the Jar file once downloaded).
Thanks for your feedback.
[Feb 14, 2013, 1:20:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sajmmon
Poland
Is this new updates feature meant only for JWS users, or also windows installers?
[Feb 14, 2013, 9:32:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Great! Although may be you already have someone for the Spanish translation, you can count me in to make it in case you need it.
[Feb 14, 2013, 10:03:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
