Re: Sweet Home 3D 4.0
Since Alt key is already used under Linux to move the current window, I guess I'll have to find an other shortcut. I would prefer a single key, but if it's not possible then I'll choose Alt + Shift.
Has the DMG for OSX also been updated to 4.0?
I'm testing the 3.8 DMG here and just got an error message by using the new feature "create photos at point of view": I selected 2 points and choosed the path to save. The rendering process started, but when i got back after a few minutes, a message informed me that there was a problem. No photos saved.
Not yet, but the Java Web Start version should work correctly. If nothing happens when you click on the previous link, double click on the SweetHome3D.4.0.beta.jnlp downloaded file.
Tonight, the Beta 8 brings a new section in the room modification dialog, that lets the user change the color of the sides of walls surrounding the modified room(s). This includes also a Recompute walls option that will split walls that are shared with other rooms. I tested it against various configurations and hope it will work correctly for you too.
I also added Furniture > Import texture and Furniture > Export to CSV format menu items to help users access these features that weren't so visible.
As DenisS suggested, it seems that we won't have that much choice for magnetism shortcut under Linux, so it will be probably Alt + shift as proposed in a coming Beta.
CSV export is very useful!
It was already available in the clipboard after selecting furniture and choosing Edit / Copy menu item. But even if it's mentioned in the help, many users weren't aware of it and clipboard is still buggy under Linux.
I am not fun of wall painting so far :-(.
The painted walls are the ones that touch the modified room, and only walls that intersect each others are recomputed at their intersection. In the more complicated cases you show, you should split walls with Plan > Split wall menu item. Not sure I'll go further than that now. Hope you can understand...
Poland
yes I knew ... I thought that there is a small difference, when copying to clipboard one has to select all rows, now I just need to select one and all are exported. On the other hand I could copy to clipboard just selected pieces.
