Total posts in this thread: 137
Posts: 137   Pages: 14   [ Previous Page | 5 6 7 8 9 10 11 12 13 14 | Next Page ]
Previous Thread This topic has been viewed 268765 times and has 136 replies Next Thread
Re: Sweet Home 3D 4.0
Thanks for your feedback.
I'm not sure to understand the behavior you want to improve. sad
At this moment, when the Aerial view centered on selection option is enabled, the distance to the rotation center, pitch angle and yaw angle are not changed when you change the selection, unless the distance is so small that you could enter in the bounding box of the selection. In the later case, the distance is increased to ensure you remain out of this box.
[Mar 20, 2013, 3:01:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Modifying the color of different materials in an object does not always work properly (in Beta 16). For example, I modifyed the colors of this model found here:
http://archive3d.net/?a=download&id=75c319b8
The model consists of 3 Materials and if I change the color of the lower part of the object, the result seems to be randomly after closing the "modify" dialog: sometimes the lower part gets the new color (as desired), sometimes the upper part (?), sometimes it changes to the color of the third material (?!?) or even one part of the model disappears (funny!). There are also other objects with that problems. How come that the behavior is just so randomly?
[Mar 21, 2013, 8:25:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The problem you describe is a known one. It has to do with the orientation of the "skin" that surrounds the model, and SH3D cannot decide what is inside, and what is outside. This can give a different result every time the model is recalculated.
It is especially known to happen with DAE models from the Sketchup Warehouse.
[Mar 21, 2013, 9:58:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Thanks for the answer, Hans. So, try and error is the only workaround? Thats ok for me, as long as I know there is no better way to do the trick.
[Mar 21, 2013, 10:21:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@, thanks for reporting this issue. I could reproduce it this way: import a zip file containing a 3DS file, save your SH3D file, close your home. Each time you reopen it, the order of materials may change and so, the index of the material color you set may concern a different material.
But there's an easy workaround: import the 3DS file and not the ZIP file it contains. This implies a different process in Sweet Home 3D because the 3D model will be internally saved as an OBJ file which doesn't produce this kind of "material reordering" (it's probably the reason why this bug was detected lately).
Argh, I was about to release the version 4.0 and if I fix this bug, I will have to rebuild all the installers! sad
Nevertheless, I'll see if it's easy to fix.
[Mar 21, 2013, 10:52:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Oh sorry about that biggrin
You are really doing a great job with SH3D and i would be more than happy if the big software company at my workplace would provide the same great support than you do!
[Mar 21, 2013, 11:50:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I fixed the bug and it will be available in the final release of the version 4.0, in the coming hours.
Don't be sorry!
You saved time to other users who won't encounter this issue, and time for people at support who won't have to answer to questions about this problem. wink
[Mar 21, 2013, 12:36:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sweet Home 3D 4.0 was released tonight
Have fun and thanks to all for your tests! smile
[Mar 21, 2013, 10:26:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yuri_fromBY
Belarus
Thank you a lot !
[Mar 23, 2013, 11:02:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
It seems that the fields to enter width and depth of furniture where mixed up; with changes the depth and vice versa (happens in the import dialog as well as in the modify dialog, so at least the behavior is constant). I tested with several objects from several sources, the behavior is always the same. It's not a big problem, but maybe you still want to fix it in the next release. smile
[Mar 29, 2013, 3:49:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
