Total posts in this thread: 137
Posts: 137   Pages: 14   [ Previous Page | 5 6 7 8 9 10 11 12 13 14 | Next Page ]
Previous Thread This topic has been viewed 270628 times and has 136 replies Next Thread
Groumphy
Belgium
Re: Sweet Home 3D 4.0
Hello,
I've found a solution !
Define a width and height in pixel (for sample). Because if we define it in %, the heigth cannot be know by the browser... ;)
This is a W3C standard... and apply by Firefox.
Have a nice day,
Xavier
Groumphy
FR - NL - EN
[Mar 10, 2013, 6:31:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Groumphy
Belgium
Please fill a feature request to ensure I don't forget it.
Done tongue
Have a nice day.
Groumphy
FR - NL - EN
[Mar 12, 2013, 6:44:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tonight, here's the last Beta (I hope) of Sweet Home 3D 4.0.
It brings the 16 translations available in the core version, and improvements in the aerial view mode, where the elevation of the rotation center is now at the half height of the items displayed in the 3D view when nothing is selected (underground items excepted), or at the half height of the selected item. Please, help to test it with as many weird cases as possible to ensure it behaves correctly.
Many thanks to all the contributors who translated the new words of this version. smile
[Mar 19, 2013, 8:35:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry, I discovered that the Beta 25 couldn't work when the new Aerial view centered on selection option was disabled. So, here's the Beta 26 and as a bonus a DMG file for Beta tests under Mac OS X.
[Mar 20, 2013, 8:33:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Emmanuel,
I like the new height-sensitive aerial view. Unfortunately, the view zooms in on details, but doesn't zoom out for a larger view. This means that after inspecting a detail, you have to use the scroll button to zoom out manually. Hopefully this can be fixed.
[Mar 20, 2013, 2:31:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback.
I'm not sure to understand the behavior you want to improve. sad
At this moment, when the Aerial view centered on selection option is enabled, the distance to the rotation center, pitch angle and yaw angle are not changed when you change the selection, unless the distance is so small that you could enter in the bounding box of the selection. In the later case, the distance is increased to ensure you remain out of this box.
[Mar 20, 2013, 3:01:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Modifying the color of different materials in an object does not always work properly (in Beta 16). For example, I modifyed the colors of this model found here:
http://archive3d.net/?a=download&id=75c319b8
The model consists of 3 Materials and if I change the color of the lower part of the object, the result seems to be randomly after closing the "modify" dialog: sometimes the lower part gets the new color (as desired), sometimes the upper part (?), sometimes it changes to the color of the third material (?!?) or even one part of the model disappears (funny!). There are also other objects with that problems. How come that the behavior is just so randomly?
[Mar 21, 2013, 8:25:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
The problem you describe is a known one. It has to do with the orientation of the "skin" that surrounds the model, and SH3D cannot decide what is inside, and what is outside. This can give a different result every time the model is recalculated.
It is especially known to happen with DAE models from the Sketchup Warehouse.
[Mar 21, 2013, 9:58:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Thanks for the answer, Hans. So, try and error is the only workaround? Thats ok for me, as long as I know there is no better way to do the trick.
[Mar 21, 2013, 10:21:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@, thanks for reporting this issue. I could reproduce it this way: import a zip file containing a 3DS file, save your SH3D file, close your home. Each time you reopen it, the order of materials may change and so, the index of the material color you set may concern a different material.
But there's an easy workaround: import the 3DS file and not the ZIP file it contains. This implies a different process in Sweet Home 3D because the 3D model will be internally saved as an OBJ file which doesn't produce this kind of "material reordering" (it's probably the reason why this bug was detected lately).
Argh, I was about to release the version 4.0 and if I fix this bug, I will have to rebuild all the installers! sad
Nevertheless, I'll see if it's easy to fix.
[Mar 21, 2013, 10:52:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
