Total posts in this thread: 137
Posts: 137   Pages: 14   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 271844 times and has 136 replies Next Thread
Re: Sweet Home 3D 4.0
Thanks for your feedback.
Meta is obtained by pressing the left Windows Key and the left Alt key simultaneously.
Do you mean that pressing Windows Key alone won't work to toggle magnetism?
[Jan 9, 2013, 7:55:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DenisS
Well, it works no more this morning... sad Another OpenJDK issue ?
I played with keyboard settings yesterday to find the Meta key, but finally reverted to defaults...
Seems like this needs some more investigations...
With Ubuntu's default settings, the Windows key is used in two different ways :
- short press displays the launcher ;
- long press displays a help screen for keyboard shortcuts.
[Jan 10, 2013, 8:45:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Windows key on my keyboard doesn't do anything at all.
Neither did it anything on my previous keyboard(s).
That said, it's easy to assign any desired action to the Windows key.
[Jan 10, 2013, 11:39:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DenisS
With default settings, and if I read correctly the keyboard map, Meta should be Shift-Alt.
But this doesn't toggle magnetism.
If I change the keyboard settings, so that Meta is on Left Windows Key (I have only one on my Logitech keyboard), it works but after one second holding the key, this help window pops up...
As a workaround, I can press Shift-Windows or Alt-Windows to avoid the popup.
Debian Wheezy, with Oracle Java, shows the same behaviour. Default Meta (Shift-Alt) doesn't work, I have to change keyboard settings to move Meta on the left Windows key. At least, Gnome shell doesn't show this popup help when you hold the Windows key.
@Hans : do you use Unity and/or Compiz on your Ubuntu ?
[Jan 10, 2013, 12:02:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Since Alt key is already used under Linux to move the current window, I guess I'll have to find an other shortcut. sad
I would prefer a single key, but if it's not possible then I'll choose Alt + Shift.
[Jan 10, 2013, 12:20:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'm using Ubuntu 12.04 with the Gnome Classic user interface.
[Jan 10, 2013, 12:27:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
DenisS
@Hans : OK, that's why your Windows key does nothing. These keys are defined by Unity.
Alt alone has a similar behaviour, opening the head up display (search bar) or the application's menu (short or long press).
Alt-Shift should be OK.
[Jan 10, 2013, 12:48:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Has the DMG for OSX also been updated to 4.0?
I'm testing the 3.8 DMG here and just got an error message by using the new feature "create photos at point of view": I selected 2 points and choosed the path to save. The rendering process started, but when i got back after a few minutes, a message informed me that there was a problem. No photos saved.
[Jan 10, 2013, 1:47:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Not yet, but the Java Web Start version should work correctly. If nothing happens when you click on the previous link, double click on the SweetHome3D.4.0.beta.jnlp downloaded file.
[Jan 10, 2013, 6:59:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tonight, the Beta 8 brings a new section in the room modification dialog, that lets the user change the color of the sides of walls surrounding the modified room(s). This includes also a Recompute walls option that will split walls that are shared with other rooms. I tested it against various configurations and hope it will work correctly for you too.
I also added Furniture > Import texture and Furniture > Export to CSV format menu items to help users access these features that weren't so visible.
As DenisS suggested, it seems that we won't have that much choice for magnetism shortcut under Linux, so it will be probably Alt + shift as proposed in a coming Beta.
[Jan 14, 2013, 8:36:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
