Posts: 13   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 18032 times and has 12 replies Next Thread
Re: Installation woes on MacBook Pro
Running the following command will help you to find where java is:
sudo find / -name java -type f
Be patient, this command should take a while.
[Nov 22, 2012, 7:22:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jhiver
Hello
FYI /usr/bin/java is a symlink to /Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/MacOS/itms/java/bin/java
Command results below, let me know what you think.
MacMimi-2:~ Mimi$ sudo find / -name java -type f
Password:
/.MobileBackups/Computer/2012-11-21-105151/Volume/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
find: /dev/fd/3: Not a directory
find: /dev/fd/4: Not a directory
/System/Library/Java/Support/CoreDeploy.bundle/Contents/JavaAppletPlugin.plugin/Contents/Home/bin/java
/Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/i586/jre1.6.0_37/bin/java
/Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/x64/jre1.6.0_37/bin/java
/usr/share/file/magic/java
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/System/Library/Java/Support/CoreDeploy.bundle/Contents/JavaAppletPlugin.plugin/Contents/Home/bin/java
find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup1.ini: No such file or directory
find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup4.ini: No such file or directory
find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup2.ini: No such file or directory
find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Users/Mimi/Library/Application Support/Firefox/Profiles/ymtjj956.default/adblockplus/patterns-backup3.ini: No such file or directory
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/MacOS/itms/java/bin/java
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-19-073958/Macintosh HD/usr/share/file/magic/java
find: /Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-075548: No such file or directory
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/System/Library/Java/Support/CoreDeploy.bundle/Contents/JavaAppletPlugin.plugin/Contents/Home/bin/java
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/i586/jre1.6.0_37/bin/java
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/Users/Mimi/Downloads/SweetHome3D-3.7-portable/jre/linux/x64/jre1.6.0_37/bin/java
/Volumes/MobileBackups/Backups.backupdb/MacMimi (2)/2012-11-23-192444/Macintosh HD/Applications/Xcode.app/Contents/Applications/Application Loader.app/Contents/MacOS/itms/java/bin/java
nfs server localhost:/8w6P4Nds7ISDmcnIrEBiuw: not responding
find: fts_read: No such file or directory
[Nov 25, 2012, 8:09:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jhiver
Hello
I managed to get it working again!
I had to sudo.
Then I removed all the Java Framework stuff using good old "rm -rf System/Library/Frameworks/JavaVM.framework/"
Then I unpacked JavaForOSX.dmg. It contains 4 .pkg files. JavaEssentials.pkg, JavaForOSX.pkg both contain a Payload file which I have moved to /JavaEssentials.tgz, /JavaForOSX.tgz
Then I dirtily did a tar zxvf of these two files while in the root folder.
At this point my Java install was totally fubar, but it was good enough to "fool" the installer. Thus, I then reran the .pkg installer from the JavaForOSX .dmg file and now at last, Sweet Home 3D is working again :-)
Pheeew...
[Nov 27, 2012, 11:04:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
