build from skratch
Is it possible to build from scratch. I'm trying to design a simple HC Ramp for a neighbor. I would like to use/create lumber (eg. 2x8x12) and assemble it myself. Is that possible w/this sw?
Re: build from skratch
Rich,
This program isn't meant to make technical drawings, but yes, you could draw a ramp. - Use an elongated triangle for the main body of the ramp. - Use elongated boxes for your vertical wooden beams. - For diagonal parts, export your wooden beams, then re-import them and give them the desired rotation.
