Re: Textures Library Editor released
MarcoH, rotating textures can be performed only in Sweet Home 3D, not in the Textures Library Editor. From version 5.5, you can set any angle.
SnakeGB, I'll see if I can improve the naming system in a future version of the Furniture Library Editor.
Campi, the Jar executable files shouldn't be unzipped, run them with Jar Launcher. Note that I don't think that the Furniture Library Editor can run with Java 9 under macOS at the moment, and you should rather run it under Java 8.
Thanks Puybaret I've done some research since I posted and indeed el captain with java 9 has caused some problems with jars. For some reason 10.11 does not have the launcher from what i understand. My next hurdle will be to to uninstall 9 (as it seams you can't install older versions over newer) since I'm not that proficient with the terminal haha
Thank you for the link since apple no longer supports legacy java
Hi Again I know I am missing something but just can't seem to get it to work. I know this is a java/os problem but perhaps you might have some insight. I got the texture and the furniture editors to open using the terminal but when I try to open a library I get nothing in the texture editor and the furniture editor crashes when opening a furniture lib. I have tried all the versions of the editors and same thing happens. I know this works because the furniture editor worked fine with 10.8
What Java version is displayed in the About dialog (click on the light bulb at the end of the toolbar)?
Bonjour, SH3D est toujours aussi plaisant à utiliser, Merci ! Je viens de mettre à jour Textures Library Editor avec la version 1.6. Mon système d'exploitation est Xubuntu, java version 11.0.6 est installé. Je lance le soft sans problème, j'accède au menu « Ouvrir une bibliothèque de textures », je sélection une bibliothèque créée il y a deux ou trois ans (Ma_Bibliotheque_textures.sh3t)... et rien ne se passe. Une idée ? Merci par avance !
A wish: could you integrate the category in the Preferences, so that we can setup a category (new or existing). OR is there any other way, to avoid manual choosing and entering for each texture in one lib.?
