Posts: 23   Pages: 3   [ Previous Page | 1 2 3 | Next Page ]
Previous Thread This topic has been viewed 11995 times and has 22 replies Next Thread
oxygen
Russia
Re: Niches in a round wall?
svetl@n@, this special websites will help you to attach image to your posts: http://www.radikal.ru/, http://www.flickr.com/ and others. You must upload pictures to any of this websites than copy the link to the picture here.
Than on Russian))
Есть сайты типа радикала, фликра и т.п. Вот ссылки: http://www.radikal.ru/, [url=http://www.flickr.com/]http://www.flickr.com/[/url.
Всё, что вам нужно - загрузить картинки на один из этих сайтов. потом скопировать полученную ссылку сюда.
[Aug 9, 2012, 3:30:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
http://s014.radikal.ru/i329/1208/d1/f85d0b436b5b.jpg
Here taie need semicircular niches in the wall! In this picture they are made in Photoshop. How do they do in sweethome 3D?
[Aug 9, 2012, 5:44:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog
Germany
Hello svetlana,
this seems to be very easy:
you create 2 walls next to each other.
in the front wall you insert the "arch" at the height you like. the "arch" has to be a "Window/Door"-type.
below the arch you insert the "invisible box" with good dimensions to cut out the lower part of the niche.
look at this example:
hope, i could help, good luck!
macfrog
[Aug 17, 2012, 10:16:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
No, you do not understand a bit: this is what I need!
See photos: (in this figure are made niche in Photoshop)
[Aug 19, 2012, 12:46:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog
Germany
so, what about this then? It's a smimilar and even simple approach:
Would have been easier if you mark your needs on that image you shown, lets say, with a red arrow or something wink
macfrog
for the more advanced user: create a smaller curved wall in the size of the niche (cutout) and re-import this as a door/windowto create a real curved cutout.
[Aug 19, 2012, 7:08:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog
Germany
Ok.
I tried to create the real curved cutout. for this you need an invisible box which is bended the same way your wall is.
This is not that easy as i thought.
I had to take the piece of wall i want to use for the cutout and export it as new furniture (as usual), but furthermore i had to remove the front part of the resulting object. Not sure if everybody here can do that as well ... sad
anyway, here's the picture:
feel free to give ideas to solve this in an easy way (we need to bend an "invisible box")
macfrog
[Aug 19, 2012, 7:54:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog
Germany
Hoi biggrin
And (finally!) this is the first version but with re-imported front wall with cutouts staying apart from the back wall.
I don't think it can be more easier, but it's still some work...
greets
macfrog
[Aug 19, 2012, 8:10:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog
Germany
Here are the photos i've made to show the results in actual renderings:
first the wooden wall(s):
scnd, the walls with different textures...
Note, the weird appearance of the brick texture is caused by the fact that it was applied to the front wall AFTER being reimported as "furniture". if you apply your texture to the front wall BEFORE exporting to obj/reimporting as furniture, it will look just fine.
macfrog
[Aug 19, 2012, 9:42:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog, thanks for sharing your tips smile
[Aug 20, 2012, 12:13:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
Thank you, very good! Handsomely!!!
Oh, I got confused with the translator ... I do not understand everything ...
you wrote about an invisible box ... where can I get it? I do not have an invisible box in the library!
how you got it?
the rectangle is written «NicheCurvedBack», where did you get it?
[Edit 2 times, last edit by Puybaret at Sep 9, 2012, 7:06:16 PM]
[Sep 9, 2012, 5:06:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
