FurnitureLibraryEditor 1.7 on Windows 7 cannot launch
I just downloaded FurnitureLibraryEditor 1.7 on my Windows 7 64 bit computer and I have Java 7 (32 bit) installed. Whenever I try to launch it, Windows says it can't open it and asks to search for a service that can open it, which is strange because this is just a local java file.
SweetHome3D runs fine and so does Art Of Illusion.
So, I did some looking around and I tried these (without success):
C:\Users\username>java -Dcom.eteks.sweethome3d.no3D=true -jar b:\FurnitureLibraryEditor-1.7.jar the result: 'java' is not recognized as an internal or external command, operable program or batch file.
Tried again:
C:\Users\username>java -jar B:\FurnitureLibraryEditor-1.7.jar the result: 'java' is not recognized as an internal or external command, operable program or batch file.
So, you see, Windows is not recognizing the command, java. Can you help?
Re: FurnitureLibraryEditor 1.7 on Windows 7 cannot launch
The error says that the system can't find java.exe in the PATH. Try to find where java is installed (probably in C:\Program Files\Java\jre7\bin), drag and drop the java.exe file in the command window to have its full path and then type -jar B:\FurnitureLibraryEditor-1.7.jar
