Version 3.5 - Old data build up issue
Hi, Thanks for creating a great program. I have been using it for a week and found it to be very useful and interesting.
The version I use is 3.5. During my usage, I have been importing and removing models many times. After a about a week, the Application Data\eTeks\Sweet Home 3D\work folder grew to over 4GB! Upon more careful inspection, I realized that when you delete a newly imported model, the program does not delete the associated zip file it created earlier. Also, it does not delete those files after I uninstall the program (moderate uninstall using revo uninstaller). So when I reinstall the program or re-import the model, it keeps adding more files (of the same models) to it.
This can be a major issue in a long-run.
By the way, if the imported models are saved in \furniture and \work folders, where are the default furniture (those that preloaded when you install the program) located?
Re: Version 3.5 - Old data build up issue
The default furniture is in resource files with the program executable.
