Total posts in this thread: 19
Posts: 19   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 9653 times and has 18 replies Next Thread
mikeycast
smile Problem using Ant, missing classes
Good evening,
I come to ask you a question once more, because I now have an issue building my application with Ant. The build is successful (I tried the jarExecutable and MacOsInstaller preselection with the good VM arguments) but when I launch my application all the functionnalities I added in two new files placed in com.eteks.sweethome3d.swing don't work. Nothing happens when I click on the button I added, when a new window should appear. I precise that appart from the part I added SweetHome is working well.
I checked and my classes are in build/classes. I don't understand why my functionnalities don't work, because Ant is set to pack "all workspace".
Thanks for your help smile ,
Mikaël
[May 24, 2012, 9:56:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problem using Ant, missing classes
What exception stack trace do you get in /Applications/Utilities/Console program?
[May 25, 2012, 7:04:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mikeycast
When I click on the button I added I get the error (I put what I found pertinent) :
.com.apple.JarLauncher: Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
Caused by: java.lang.NoClassDefFoundError: com/lowagie/text/Elementat com.eteks.sweethome3d.swing.MonitoringFrame.createSensorPagePanel(Unknown Source)
Caused by: java.lang.ClassNotFoundException: Class com.lowagie.text.Element
at com.eteks.sweethome3d.tools.ExtensionsClassLoader.findClass(Unknown Source)
[May 25, 2012, 9:05:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
com.lowagie is the package base of iText library.
Could you check the source code version you use?
Because I remember that I fixed in version 3.5 an issue about iText version that was wrong in SweetHome3DBootstrap.java.
[May 25, 2012, 12:06:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mikeycast
Ok this fixes my issue, I just refreshed the file you cited. Now my window is lauching but I have some other issues :
- First, the "é,è,à" characters are not printed well, even though Ant is encoding in UTF-8...
- Secondly, I have a JPanel composed with JCheckBox which is absent sad
Can you continue to help me please? I don't have any error message in the console this time.
[May 26, 2012, 10:24:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mikeycast
Hello,
an idea where it can come from? Of why my panel is not showed?
The panel is printed thanks to values from a distant database. Could it be a problem of connexion? Are the supplementary sql packages automatically added by Ant?
Thanks for your help,
Mikael
[May 31, 2012, 6:10:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Without source code, it's impossible to be sure. You probably didn't pay enough attention to the encoding of the files that contain accented letters, and executed your plug-in on a different OS.
[May 31, 2012, 8:04:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mikeycast
Thank you, and what do you think about the sql connection problem?
I've added mysql-connector-java-5.1.18-bin.jar to the libs but Ant may not include it.
Should normally Ant add the .jar I added in /lib or do I have to force it by modifying the build.xml file?
I think about this because the symptoms are the same than when I had some problems connecting to the database.
Anyway, I don't have any messages in the Console.
[Jun 3, 2012, 10:20:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mikeycast
Hello, I've juste read the post from Mitsaki and so I've added my packages to the SweetHome3DBootstrap, in the extensionJarsAndDlls array. And thanks to your link I know now that my .jar are included during the building, while they are in /lib.
Still the connection to the database doesn't work and I don't have any messages in the console.
Do you have any ideas of other things to do to make it work?
Please, I have 3 days left to fix it until my presentation...
[Jun 5, 2012, 5:03:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You may have to add the packages of your project in applicationPackages of SweetHome3DBootstrap too.
If you have nothing in the console, run in a Terminal window your JAR executable file with command:
java -jar jarExecutableFile.jar
Without source code or a stack trace it will be difficult to help you further. I just can't guess what is wrong. I don't even know why you use a database and how!!!
[Jun 5, 2012, 6:50:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
