Re: Sloped Walls question
If you use the above formula to calculate the slope, you can then use (in this order) - CopyAsNewFurniture (to eliminate the floor) (see plug-ins PDF), - Export to OBJ format (to export the wall segment as a model) and - Import furniture.
Make sure that during importation you rotate the wall segment 180 degrees, so that the sloping side ends up at the bottom.
For one horizontal or vertical wall, no need to install CopyAsNewFurniture plugin.
