PLAN>Modify walls
Hi, I have just started using this program and am getting on fine with it apart from there seems to be a few menu options greyed out on the menu, specifically 'PLAN>MODIFY WALLS', so i'm unable to edit the floor colour etc. Any ideas why this might be? Thanks James
Re: PLAN>Modify walls
Hi Hans, Sorry I meant to say specifically 'MODIFY ROOMS' is greyed out in the menu, so I can't access it. I have created 1 room. The plan is unlocked. Thanks James
You have to select first the rooms you want to modify. If you want to change them, select all, it's not a problem if the selection contains other kinds of objects.
Hi Emmanuel, I have selected the rooms but it still doesn't let me have access to 'modify rooms'. See screen print below... [IMG]http://i50.tinypic.com/309pmra.jpg[/IMG]
Am I selecting it correctly? Do all the walls have to be 'joined'? it looks like all the walls are joined apart from one wall that just overlaps at the corner and won't connect to the other wall.
