Re: Sweet Home 3D 3.0
Khongorbayar,
A circle can be made by drawing two semi-circular walls. 1 - draw a wall from left to right, click only once, then 2 - draw a wall from right to left, double-click to end the wall. 3 - select the first wall, right-click and select Modify walls 4 - if necessary correct the exact X,Y coordinates, then 5 - change the Angle to 180 degrees 6 - click OK 7 - select the second wall, right-click and select Modify walls 8 - change the X,Y coordinates so that the end of the second wall is at EXACTLY the same position as the start of the first wall 9 - change the Angle to 180 degrees 10 - click OK
You should now have a circle made of two walls.
If you install the AdvancedEdit plug-in (PDF) you can use the function Connect walls to join the two sections of the wall.
