Total posts in this thread: 5
Previous Thread This topic has been viewed 3628 times and has 4 replies Next Thread
dimm
Plugins do not work in the applet
Hello,
Goal: make a plugin that works in the applet.
What I also tried :
I edited the calculatewalls plugin to enable toolbar icon. Made the jar. The plugin works fine in the standalone version and the icon appears on the toolbar, but the plugin breaks the applet( .. pluginUrls:"plugins/calculateWalls.jar", .. ).
Is there a plugin that works in the applet? Or explanation how to make it happen?
Btw, learning Java so please include more details if possible.
Thanks in advance
[Apr 12, 2012, 8:45:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Plugins do not work in the applet
I'm going to check if this feature works correctly.
Nevertheless, as applets don't display a menu bar, only plug-ins displaying a button in the tool bar can be used within an applet (the TOOL_BAR property of its plug-in action must be set to Boolean.TRUE), and calculateWalls.jar isn't usable in that case.
[Apr 13, 2012, 10:24:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dimm
Puybaret, thank you for looking into this.
Here is the error I get in the console. Again the same jar works fine with the stand alone.
Exception in thread "AWT-EventQueue-2" java.lang.LinkageError: loader constraint violation: loader (instance of com/eteks/sweethome3d/tools/ExtensionsClassLoader) previously initiated loading for a different type with name "com/eteks/sweethome3d/plugin/PluginAction"
at java.lang.ClassLoader.defineClass1(Native Method)
[Apr 16, 2012, 4:27:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sajmmon
Poland
I dont know if my experience would help, but I was getting the same error when experimenting with JAWS. In my case a piece of code in my plugin worked fine. However, a piece of code that I added to Sweethome SRC in a new package needed to be implicitly stated in:
com.eteks.sweethome3d.SweetHome3DBootstrap
in the list of application packages
Cheers
[Apr 16, 2012, 6:41:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dimm
Solved. The issue was in the meatware (me). Please delete thread.
[May 23, 2012, 10:38:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
