Total posts in this thread: 4
Previous Thread This topic has been viewed 6106 times and has 3 replies Next Thread
petercseri
roof window
I would like to find out how it is possible to make a window on an inclined roof... and after trying to export and than inport the window, it would become non transparent. not useful. still working on it. please help.
Thank you so much
peter
[Mar 27, 2012, 8:53:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: roof window
You probably discarded the accompanying MTL file after exportation and before importation, or moved the OBJ file without its MTL file before reimporting the OBJ file.
[Mar 28, 2012, 8:39:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
petercseri
Re: roof window
right you are!!! thanx!!! still the question remains, how is it possible to build an inclined roof and buils a window into it... so far i did this export furniture than to obj and back into the project method to make the roof but now as i fit the window in the roof doesnt behave the same as a wall would. i mean the roof doesnt open up the same way as a vertical does if inserting a door or window. well... that is still a puzzle here. thanx for the reply, it was helping!!!!
[Mar 29, 2012, 7:43:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
coldcomfort
Re: roof window
@peter. I'm not sure what problem you're facing now but the procedure is pretty simple:
-build the walls in the shape you want for the roof (one panel, two angled panels or even 3 with the middle one flat, as a roof window);
-insert the window in the walls at the right position and change its size accordingly;
-choose the color/texture for the inside and outside (roof tile texture) walls.
-select it and choose 'copy as new furniture' from tools menu (assuming you installed the "copy as new furniture' plugin http://www.sweethome3d.com/pluginsUserGuide.pdf );
-after you paste the new object and delete the old one, 'export to OBJ format' from the 3D window;
Now you should be able to import it as new furniture and rotate it as you need.
[Edit 1 times, last edit by coldcomfort at Mar 29, 2012, 12:55:40 PM]
[Mar 29, 2012, 12:54:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
