Previous Thread This topic has been viewed 3192 times and has 2 replies Next Thread
LNS
SH3D cant save my project!!
Hey guys,
i just started using this application today, and i already love it! So thanks to the people who engineered it, its fantastic :)
However, throughout the work i saved my project from time to time. But after a few savings it did not save my "updates" anymore. I also tried to save it under another file name, but it just wont save!!
Does anyone had a similar problem or has a solution to this?
Thanks for the help!
[Mar 18, 2012, 10:26:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: SH3D cant save my project!!
Leonard,
Although not exactly your problem, this what the FAQ says. It may help you in some way.
Sweet Home 3D refuses to open a SH3D file I created, or opens it incorrectly. Is there a way to recover it?
When Sweet Home 3D saves a home, it attempts to create first a temporary file that replaces the previously saved file only once the temporary file is successfully created. This ensures that there's very little chance that your previous SH3D file gets corrupted even if the last save operation failed. Nevertheless some users still report they can't open their SH3D file. In case this problem happens to you, please try to describe to the developer of Sweet Home 3D the circumstances of the last save operation (was is successful?), whether the SH3D file was transferred or not by email, ftp or with an USB key, what happens when you try to open the file that causes problems, and join a compressed version of your SH3D file if possible. Finally, try next time to back up regularly your SH3D files, like you should do for any document you spend hours on.
Another cause of your problem could be that you imported a faulty piece of furniture. If so, delete it, and try again.
[Mar 19, 2012, 2:34:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LNS
I now tested every single furniture since the problem occured, and i think i found the bad one. it works fine now and saves my updates again! Thank you for the quick help!!!!
[Mar 19, 2012, 11:36:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
