Total posts in this thread: 8
Previous Thread This topic has been viewed 3240 times and has 7 replies Next Thread
Lolapal
Italia
From 2.6 to 3.4 version
On my Windows Xp I have installed a long time version 2.6 of Sweet Home, and it works perfectly.
If I upgrade to the latest 3.4 version, let me know if I have problems opening my (very important!) SH3D old files.
If you think I can safely upgrade version, I would like to know what the correct way to do it (uninstall the previous or install directly the new over?).Excuse my bad English,thanks!
[Mar 11, 2012, 7:12:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: From 2.6 to 3.4 version
Lola,
New versions are compatible with old versions. So you can install v3.4 and open your old files.
Please note that files saved with a newer version cannot be used reliably with older versions.
On my PC (which uses Ubuntu as operating system) I have all versions installed next to each other (well, at least from v2.1), so I can always go back to an older versions.
[Mar 11, 2012, 7:35:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lolapal
Italia
Ok,thanks,but I have to uninstall version 2.6 before? Thanks
[Mar 11, 2012, 7:55:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You don't have to uninstall the version 2.6 to install the version 3.4.
[Mar 11, 2012, 8:41:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lolapal
Italia
is required to keep the two versions at once? I can not just keep the 3.4. as it opens my old hs3d? thanks
[Mar 11, 2012, 8:58:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lola,
If you keep both versions, first start SH3D, then open the file you want to work on.
This way you avoid that Windows determines which version it uses to open your file.
[Mar 11, 2012, 9:13:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
By default, installing version 3.4 will overwrite the version 2.6
[Mar 11, 2012, 9:13:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lolapal
Italia
Ok,thanks!!
[Mar 11, 2012, 9:31:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
