Please Add These Features Too (Must have Functions)
I really liked the SH very much, I'm learning and mastering it I noticed that some things can't be made:
1. I couldn't Elevate the wall (The function doesn't exists as it is on decorations) 2. Add ability to build a house with Frames (with Massive poles or something like) I was building (as test) my house and stuck there, then i tried the cube (Box from the default library) as massive poles for framing, I did it, but to say the truth it was very tiresome ;)
3. Add ability to change windows function (One Paned,two or three) 4. In 2D The staircase to be displayed as it is in real 2D plans, Please add some standard staircases in library 5. Please Simplify the view options (2D With 3D, Only 2D, when working i have to resize the divided window to work comfortably) 6. Toolbar customization... 7. Very Must Have option: Add transparency option for walls
Re: Please Add These Features Too (Must have Functions)
1. Please use the multiple levels feature available in the new version 3.4
2. You can make holes in walls with large Service hatch objects
3. I don't think that will happen anytime soon. Just import other models if the default ones are not enough
4. If you want more staicase models, feel free to contribute. The drawing in the plan can be done with this trick that I might include in a coming version
5. I don't understand why the divider isn't enough for you
6. Maybe one day, the toolbar will be customizable, but it's an expensive feature which doesn't bring that much benefit
7. Look in the modification pane of the 3D view
