Sweet Home 3D Forum Category:Open discussions Forum:Wishlist Thread: Directed Zoom / Rotating Angle for Top View / Save Partial Render in Captures / Establish Default Value for Brightness
Thread Status: Active Total posts in this thread: 1
Hi
I've detected a few interesting features: - Zoom based on the current mouse pointer location, similar as it works in some CAD applications. We might call it "directed zoom", instead of the current "centered zoom". - If you want to get a capture in "Top view mode" (I don't know the proper name in english) then you might be interested in getting a precise angle rotation of the view, usually 0º, but right now it's now an easy task to rotate to a concrete angle. Because of that having a way to define the exact angle (just for this view mode) would do the job. - Also related to capturing if you decide to stop one then you lose the whole rendering. What if you only need to render the center of the view? Instead of waiting for the render to end it makes sense to stop it once this central part has been rendered, even if the borders haven't been done yet. Ok, you save the png file and part of it is black, but that's not a problem, as long as you are not interested on it. - For doors/windows and boxes in the last version I tested the default value for brightness is Brilliant instead of Matt. With this you get some unexpected reflections, and of course you can manually change that, but having a way to modify the default value seems to be a better way to solve it.
