Total posts in this thread: 20
Posts: 20   Pages: 2   [ Previous Page | 1 2 | Next Page ]
Previous Thread This topic has been viewed 30804 times and has 19 replies Next Thread
Re: Lampshade transparency
Be sure to give the lampshade a color darker than white otherwise it will be rendered completely transparent. You can test also with textures but it might be buggy like here.
[Sep 28, 2011, 10:36:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tic
Emmanuel, could you please post the mtl assignments of your cylindrical lampshade? I'd like to compare it to mine.
[Sep 29, 2011, 8:29:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tic if you want to know these values, just create an empty document in which you copy/paste only the lampshade and then export it to OBJ format.
[Sep 29, 2011, 10:22:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tic
Great!
Thank you so much.. sorry..I'm sitll learning.. smile
[Sep 29, 2011, 10:49:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tic
Emmanuel,
I'm back after more tests: I think that the bad rendering is due to the Obj export method of the modelling software I use (Wings3D).
On the left you can see your original lampshade and on the right the same object imported in wings3d and then re-exported as .obj.
I manteined the same mtl file for both.
[Sep 30, 2011, 7:45:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If the mtl file is the same in both cases, it's probably due to some normals that were changed in Wings3D.
[Oct 1, 2011, 12:47:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tic
You're right, I find out that SH3D and wings3d generate different normal directions: while in SH3D vertex normals are orthogonal to faces, in wings3d they spread out radially;
Also the amount of normals and faces is different.
This affercts somehow surface reflection and material refraction.
I tried to export form wings3d to 3DS and then import in SH3D but unfortunately the resutl is quite the same.
So I think there's no way to solve the problem if I want to keep on modelling in wings3d sad
[Oct 1, 2011, 12:36:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tic,
Instead of Wings3D, you could try Art of Illusion , or Misfit Model 3D .
[Oct 1, 2011, 2:20:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Or maybe find the way to configure normals computation in Wings3D.
[Oct 1, 2011, 3:54:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tic
Thank you guys for your suuport and suggestions!
Even though I am not as much familiar with AoI or MM3D as I am with Wings3D, I'll try them.
At the moment there is no other choice for me since I have no knoledge in processinig data files... but it could be a challange for the future, never say never...
Thanks again
[Oct 1, 2011, 5:07:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
