Re: Lampshade transparency
Be sure to give the lampshade a color darker than white otherwise it will be rendered completely transparent. You can test also with textures but it might be buggy like here.
Tic if you want to know these values, just create an empty document in which you copy/paste only the lampshade and then export it to OBJ format.
Emmanuel, I'm back after more tests: I think that the bad rendering is due to the Obj export method of the modelling software I use (Wings3D).
On the left you can see your original lampshade and on the right the same object imported in wings3d and then re-exported as .obj. I manteined the same mtl file for both.
If the mtl file is the same in both cases, it's probably due to some normals that were changed in Wings3D.
You're right, I find out that SH3D and wings3d generate different normal directions: while in SH3D vertex normals are orthogonal to faces, in wings3d they spread out radially; Also the amount of normals and faces is different.
This affercts somehow surface reflection and material refraction.
I tried to export form wings3d to 3DS and then import in SH3D but unfortunately the resutl is quite the same.
So I think there's no way to solve the problem if I want to keep on modelling in wings3d
Thank you guys for your suuport and suggestions! Even though I am not as much familiar with AoI or MM3D as I am with Wings3D, I'll try them. At the moment there is no other choice for me since I have no knoledge in processinig data files... but it could be a challange for the future, never say never...
