Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 177907 times and has 51 replies Next Thread
Re: Sweet Home 3D 3.4
Thank you for your feedback.
Sounds like there are some problems with Ubuntu 11.10. I just tried under Ubuntu 11.04 and didn't noticed the problems you reported about shorcuts, drag & drop and furniture handles. Can you check everything works when you use menu items?
When I draw a simple house with two floors (= two layers), and then use Modify layer to increase the thickness of the ceiling and decrease the height of the walls of the top layer, there is a "strange" overlap visible in the walls, that corresponds with the decrease of wall height.
You should decrease the height of the lower level walls also. Wall heights are independent from level height. This has some drawbacks like the one you reported but lets you also completely free to manage walls the way you want, something required to manage intermediate levels. Level height is actually only used to compute ceilings.
The compass has moved to the "old" position of 0,0.
I guess you edited an old document. On a new document, the location is at the same place.
When level 1 is active, it's still possible to delete furniture on level 0.
I couldn't reproduce this bug, except if the selected piece is high enough to appear on a higher level, in which case I found normal to be able to select it and delete it.
[Oct 28, 2011, 9:17:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
I'm glad to report that the problems I reported don't exist anymore. Of course I don't understand what caused them, it's as if half of my computer was asleep.
[Oct 29, 2011, 9:30:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great to read it now works for you Hans. smile
Tonight, Beta 6 fixes a few bugs found in level management, while trying to build the attached file, built from the house plan available on this site. For your information, it took me more than 6 hours to reproduce the plan and the roof of this quite complicated house with 2 levels.
Attachment House89.sh3d (249462 bytes) (Download count: 5985) (House built from plans available at http://www.construiresamaison.com/plans-maiso...cilienne-de-caractere-a89)
[Oct 30, 2011, 2:37:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hello all,
If you're using Ubuntu 11.10, 64 bits, you may have difficulties using the newest beta.
Install the original Sun Java and your problem will be solved.
Here is a help page for easy installation. These are the commands I used:
sudo add-apt-repository "deb http://archive.canonical.com/ lucid partner"
sudo apt-get update
sudo apt-get install sun-java6-jre sun-java6-bin sun-java6-jdk sun-java6-plugin sun-java6-fonts
[Oct 31, 2011, 4:47:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Today's Beta 7 brought 3D view > Display all levels and 3D view > Display selected level menu items, and improved magnetism during rooms drawing (you should have much less problem to draw a simple rectangle).
I also increased a little the sensitivity of magnetism.
[Nov 2, 2011, 2:21:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pial
And now beta 8 ! ;-)
Tanks a lot for that pretty good job Emmanuel !
Pierre
[Nov 4, 2011, 9:53:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tonight's Beta 9 adds support for levels at a negative elevation. Hope you like it. smile
As soon as you place an object, a room or a surface surrounded by walls at a level with a negative elevation, Sweet Home 3D will compute a hole that will surround the added item. Multiple underground levels containing items of different sizes are supported.
Note that the virtual visitor can't go below elevation 0, and I'm not sure I'll add that in the next update (keeping the visitor location in the home when underground isn't so easy).
[Edit 1 times, last edit by Puybaret at Nov 4, 2011, 10:43:42 PM]
[Nov 4, 2011, 10:39:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
And here's a Beta 10 because I forgot to make the required changes to the photo creation tool.
Which swimming pool will you prefer? wink
[Nov 4, 2011, 11:30:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pial
applause Re: Sweet Home 3D 3.4
I prefer the left one.
Though "underground elevation" sounds a bit strange biggrin ,
anyway it's a huge step upgrade. Great job !
How can you make it so quickly ?
Pierre
[Nov 5, 2011, 2:19:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Beta 11 brings a few new small features and improvements:
- Added New floors thickness field in preferences pane,
- Added a button to import language libraries in preferences pane to make it easier to install SH3L files when file association doesn't work (there are now 3 SH3L available files: Traditional Chinese , Korean and Finnish),
- Added some tooltips to show the current angle on rotation axis in the 2nd step of the Import furniture wizard,
- Added a table in the Level modification dialog to help users compare the values of the edited level with the ones of other levels.
And as showed in the previous dialog, I checked that the new level feature was able to handle correctly raised floor and false ceiling. This test was made on the attached example that shows the 4 following levels when 3D view > Display selected level menu item is checked (the outer level isn't mandatory but still nice to have).
Raised floor:
Arranged space:
False ceiling:
I guess that a few ones among you are going to be happy because levels actually behave like layers when they are at the same elevation, excepted that walls are always displayed when they are at the same elevation as a level elevation, but I don't feel it's annoying for a software like Sweet Home 3D.
Like always your comments will be appreciated. smile
Attachment OfficeWithRaisedFloorAndFalseCeiling.sh3d (969045 bytes) (Download count: 99797) (Office with raised floor and false ceiling)
[Nov 7, 2011, 2:18:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
