Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 ]
Previous Thread This topic has been viewed 171648 times and has 51 replies Next Thread
pencilart
Re: Sweet Home 3D 3.4
Great work Emmanuel!
I made a swimming pool in the back yard of a house I'm testing. I also made a "basement" but it's more like a crawl space. You can't see it unless you go down there. :)
I'm attaching snapshots so you can see.
Attachment SH3D-34betafunweb.jpeg (146069 bytes) (Download count: 333344) (Hopefully, these will show in order: Pic #1: Screenshot of the house with a transparent view so you can see the floors with furniture. 2nd pic: the house rendered with the sunflow renderer. )
Attachment Sweethome-beta34outside-web.png (192914 bytes) (Download count: 311515) (Hopefully, these will show in order: Pic #1: Screenshot of the house with a transparent view so you can see the floors with furniture. 2nd pic: the house rendered with the sunflow renderer. )
[Dec 19, 2011, 9:33:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sweet Home 3D 3.4 was released tonight.
Thank you all for your feedback and support. smile
[Dec 21, 2011, 2:00:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I just thought of a question about importing libraries:
When importing a furniture library and there is a piece that has the same name as one already in the catalog, will it ask to rename it or simply overwrite it, or make a duplicate of it?
I'm asking because I'm planning to import my furniture library onto this new(ish) computer and I have a few of those pieces in my catalog already and I don't want a lot of unnecessary duplicates. I would need to know the difference between the newly imported pieces and the old ones so that I could go back and delete the old ones. This is because I have set different default measurements on some of them.
[Dec 21, 2011, 1:56:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I just discovered something with the Windows version (on Windows 7 that has Java version 7 update 2 installed).
The "virtual visit" does not seem to work. When "virtual visit" is selected, the view is still the "aerial view" but there's no home showing at all and the view does not change despite moving the visitor around.
[Dec 22, 2011, 7:15:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Even if Sweet Home 3D isn't officially supported under Java 7, I just tried and noticed that sometimes the 3D view becomes grey and completely empty (for example after resizing the window). Is that what you mean?
I also noticed that the Java Web Start version can't be installed with Java 7 update 2 under Windows. Fortunately, the download page suggests to use the installer in case of problem.
[Dec 22, 2011, 9:21:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I just tried it again and now the virtual visit is working both for full screen and windowed. Go figure. I hadn't done anything to it.
Now that you told me about the java webstart version not running SH3d with Java 7 update 2, I'm going to try it out for the fun of it. :)
ok, I just tried it out and it ran without problems. I did come across this dialog box about file associations or something. See my attached screenshot. I just said "yes" to the questions a few times. Otherwise it ran fine, and with the webstart version, I was even able to open a test home.
Attachment sh3dvsjws7u2.jpg (171046 bytes) (Download count: 331885) (Opening SH3D 3.4 with JavaWS using Java 7 Update 2)
[Edit 2 times, last edit by pencilart at Dec 22, 2011, 9:57:39 PM]
[Dec 22, 2011, 9:46:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
