Re: Sweet Home 3D 3.4
That stairs test worked great! I'm very excited about the new features and I can hardly wait until the release! :D But I know that great things can't be rushed. :D
Great improvement, congratulations, Emmanuel, though when I downloaded the new version, I wish it was an update for the zoom problem in bird view mode ! Next time may be ?
---------------------- Pierre
I updated the beta version to generate automatically the bottom part of a floor at upper levels, when no ceiling part was drawn at the lower level. It contains also a few bug fixes reported by a nice team of Swedish students who test Sweet Home 3D at this time. Nice job guys!
Sorry I don't think I will change bird view mode anytime soon, except for this case.
Thank you for your feedback.
I fixed a bug in the version 3.4 beta 37 to improve performances when you set textures on many different walls, rooms or furniture. Hope you can confirm it works better when you try to modify these objects (just trying to move them should make a difference).
Emmanuel,
How many textures would you consider to be "many" textures? I prepared a room with 20 boxes in it, all in all 30 different textures, with a compressed file size of 4.1 MB. I made a second room with 82 different textures, and a compressed file size of 10.3 MB. Is that enough?
Moving boxes is as smooth as I would expect. Rendering in Q3 with just the ceiling light at 800x800 is fast. The 3D preview rotates smoothly as well.
I can share the file(s), or prepare an even bigger one.
[Edit 1 times,
last edit by hansmex at Dec 17, 2011, 3:38:32 PM]
Thank you for your tests.
[...] Is that enough?
I would say it depends on the power of your processor. Recently, some users complained about some performance regression and the bug I found could lead to some performance loss. But the slowing effect could take place only when trying to compute 3D updates, after moving wall, rooms or furniture which use some texture, or changing their size. Rendering speed won't get faster in the photo creation dialog.
Emmanuel,
I have a dual core machine, not sure which processor exactly, about 3-4 yrs old. Maybe the problem is mainly with "older" machines with even lower specs?
It wasn't annoying on my Intel i7 too, but I clearly measured a waste of computation in textures handling that wasn't supposed to happen.
In version 3.4 beta 38, I improved ground management to be able to handle elevations up to 1000m without viewing some black parts at the horizon in the 3D view. Miserably, SunFlow renderer starts to render incorrectly the ground at an elevation higher than 100m, and it's getting worse at higher elevations. Not sure I'll try to fix that soon or I'll limit it back to 100m.
[Edit 3 times,
last edit by Puybaret at Dec 18, 2011, 12:09:27 PM]
