Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 168316 times and has 51 replies Next Thread
Re: Sweet Home 3D 3.4
Emmanuel,
I think I found a small bug in v3.4 b11 that concerns creating a room.
In the attached file the outline of a building is drawn. You will find that it is impossible to create a room by double-clicking inside this shape.
If you inspect the connection of the two wall segments marked with a red circle, you will see that this connection isn't at a 90 degree angle, but is slanted or skewed. It looks a bit like a problem you fixed earlier.
Now, if you bisect the room, you will find that you can create a room by double-clicking in the part without the red circle, but NOT in the part where the slanted connection is.
Attachment bug in Draw Room.sh3d (60201 bytes) (Download count: 564)
[Edit 1 times, last edit by hansmex at Nov 7, 2011, 4:42:11 PM]
[Nov 7, 2011, 3:49:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Was it similar to this bug?
I couldn't reproduce your problem, the walls looked correct and I had no problem to create a room with a double click. Maybe it was due to a temporary computed value that disappeared when the program was relaunched?
[Nov 7, 2011, 8:12:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
After reloading the file, the problem was solved.
It was similar to the first stages of the bug you showed. That bug also started with a "strange" connection, that became worse after splitting the wall again.
[Nov 7, 2011, 11:53:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I just released a version 3.4 beta 13 with a few bug fixes.
[Nov 10, 2011, 11:44:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tiz
Hello! I'm using this version because I'm tring to project the house that my housband and me are buying. It'is on two levels, but each one is on two different levels (4 steps). I've never used a 3D software before SH3D... a lot of instruction are in English (wich is not my language...), in spite of all I'm using it sucesfully! So: very good job guys, you are great! Thanks a lot!
[Nov 10, 2011, 12:54:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you Tiz for your feedback. smile
I just released the version 3.4 Beta 15 with some small bug fixes, and two new help pages for level management (available also here: Adding levels and Editing levels).
Please tell me if you feel that my explanations aren't clear enough or that I missed some important information.
[Nov 14, 2011, 9:23:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I released version 3.4 Beta 17 with more bug fixes and the ability to toggle the visibility of a piece of furniture by clicking on its Visible check box in the furniture list.
It includes also Italian and Czech updated translation. A special thank to Ondrej Dolejsi, our new Czech contributor. smile
[Nov 17, 2011, 4:44:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I released version 3.4 Beta 18 where I added a Select object submenu in the contextual menu of the plan that will let the user select an object among the superimposed ones that appear where he clicked. This menu won't appear if there's no object under the cursor.
Hope you'll like it smile
[Nov 18, 2011, 9:46:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pial
I love it !!!
Pierre
[Nov 18, 2011, 4:55:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I tried out version 3.4 Beta 18 and so far, I love it!
Once I got "the hang" of things, it's really fun to play with! :D
A render of the kitchen area:
http://i64.photobucket.com/albums/h186/gymnar...rsionsh3d3-4Beta19web.jpg
[Nov 18, 2011, 9:59:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
