jrios
Re: second execute crashes the program
Quite a strange behavior! You probably have two Java virtual machines installed on your system. Unless you perfectly know how to handle this, I would give a try to the installer version. Hello, I have download this link, unzip and execute and I have the same result. Opens the program and closes itself. With this version I drop the apps, I clean the cache but this not works.
I execute javaws -viewer and in the about version I have Oracle (build 1.6.0_26-b03)
When I execute this file (SweetHome3D) the apps splash is the SweetHome3D but the first execute the java spalsh is the Oracle.
I execute this dpkg -l | grep "java" and this is the software in my machine
ii ca-certificates-java 20100412 Common CA certificates (JKS keystore) ii java-common 0.38 Base of all Java packages ii libaccess-bridge-java 1.26.2-5 Java Access Bridge for GNOME ii libaccess-bridge-java-jni 1.26.2-5 Java Access Bridge for GNOME (jni bindings) ii libbcmail-java 1.44+dfsg-2ubuntu1 Bouncy Castle generators/processors for S/MIME and CMS ii libbcmail-java-gcj 1.44+dfsg-2ubuntu1 Bouncy Castle generators/processors for S/MIME and CMS ii libbcprov-java 1.44+dfsg-2ubuntu1 Bouncy Castle Java Cryptographic Service Provider ii libcommons-beanutils-java 1.8.3-1 utility for manipulating JavaBeans ii libcommons-collections3-java 3.2.1-4 A set of abstract data type interfaces and implementations ii libcommons-compress-java 1.0-1 Java API for working with tar, zip and bzip2 files ii libcommons-digester-java 1.8.1-2 Rule based XML Java object mapping tool ii libcommons-logging-java 1.1.1-8 commmon wrapper interface for several logging APIs ii libdb-je-java 3.3.62-3 Oracle Berkeley Database Java Edition ii libdb4.7-java 4.7.25-9 Berkeley v4.7 Database Libraries for Java ii libdb4.7-java-gcj 4.7.25-9 Berkeley v4.7 Database Libraries for Java (native code) ii libgnuinet-java 1.1.1-4 extension library to provide extra network protocol support ii libgnujaf-java 1.1.1-5 free implementation of the javabeans activation framework ii libgnumail-java 1.1.2-5 free implementation of the javamail API ii libhsqldb-java 1.8.0.10-6.1ubuntu1 Java SQL database engine ii libicu4j-java 4.0.1.1-1 Library for unicode support and internalisation ii libitext-java 2.1.7-2 Java Library to create and manipulate PDF on the fly ii libitext-java-gcj 2.1.7-2 Java Library to create and manipulate PDF on the fly ii libjaxp1.3-java 1.3.04-5ubuntu3 Java XML parser and transformer APIs (DOM, SAX, JAXP, TrAX) ii libjline-java 0.9.94-5 Java library for handling console input ii libjtidy-java 7+svn20070309-4 a Java port of HTML Tidy, a HTML syntax checker and pretty printer ii liblucene2-java 2.9.2+ds1-1 Full-text search engine library for Java(TM) ii libregexp-java 1.5-2 Regular expression library for Java ii libreoffice-java-common 1:3.3.2-1ubuntu2~maverick1 office productivity suite -- arch-independent Java support files ii libservlet2.5-java 6.0.28-2ubuntu1.2 Servlet 2.5 and JSP 2.1 Java API classes ii plasma-scriptengine-javascript 4:4.5.5-0ubuntu2 the JavaScript script engine for Plasma ii sun-java6-bin 6.26-1maverick1 Sun Java(TM) Runtime Environment (JRE) 6 (architecture dependent files) ii sun-java6-jre 6.26-1maverick1 Sun Java(TM) Runtime Environment (JRE) 6 (architecture independent files) ii sun-java6-plugin 6.26-1maverick1 Java(TM) Plug-in, Java SE 6 ii tzdata-java 2011g-0ubuntu0.10.10 time zone and daylight-saving time data for use by java runtimes
[Aug 20, 2011, 9:03:54 AM]
[Link]
