Previous Thread This topic has been viewed 4292 times and has 2 replies Next Thread
Clovis
Problem with open door size
Hi there
Tks for the solution on the other post.
I'm in Brasil and here the walls has 10cm not 7,5 .
I configured the size of the walls and its ok.
The problem is with half open door.
When I put the open door at the wall, its gets the wall thiknes, its ok, but the size of te door at 3d view became bigger, not the open area, but the door it self.
in a 90cm door, the leng goes to 123cm, and is not possible to change it.
Clovis
[Jun 18, 2011, 7:23:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problem with open door size
See the suggestion I posted here on 2010-03-12.
[Jun 18, 2011, 7:43:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Clovis,
There is a simple solution for your problem. First insert a hatch that has the size of your door, then insert the door in the hatch using the cursor keys or exact coordinates. That way the door doesn't resize. You can find the hatch here and here.
There is also a more complex solution, which I have copied from the forum into my Tips & Tricks manual, which you can find here.
[Jun 18, 2011, 7:45:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
