Total posts in this thread: 8
Previous Thread This topic has been viewed 6136 times and has 7 replies Next Thread
emmaleelazar
confused can i change centre point in 3d view
ok i've been working with this program for a couple day now and i'm wondering if you can change the 3d view centre point. it is really starting to piss my off. i want an areal view of a certain room but zoomed in. When ever i try to zoom in on the room it zooms to the centre point. i really hope there is a way of fixing this because the programs great otherwise confused
[May 20, 2011, 7:01:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: can i change centre point in 3d view
Emmalee,
No, you can't. Yes, you can.
Although there's no way to change the 3D centerpoint, there are two workarounds.
1 - Put an object (far) off-center, so that the center shifts in the direction you desire.
2 - Using the Virtual visitor you can set a (very) high viewpoint to get exactly the viewpoint you want. You can store several points of view, so you can easily switch from one point of view to another.
[May 20, 2011, 7:17:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
karasu.a
Steps:
1 - Preferences
2 - Aerial view centered on selection
Change it to Enable
[Mar 8, 2022, 10:52:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Or you can try the Pan 3D view plugin.
[Mar 9, 2022, 10:29:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
Both methods are fine, as suggested. Which one to use depends on the situation you are currently working in. You quickly get used to the changes and the use becomes automatic after a while.
[Jan 21, 2025, 2:22:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Status: Online
Dear Mario,
What you are doing is called Necroposting, or Thread Necromancy: Posting to long-dead threads. You are also doing it on many threads which is basically spamming. Both of these are annoying, and usually frowned upon. Please don't do that.
[Jan 21, 2025, 5:27:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Dear Mario,
I suspect "Mario" is either an account from Space Mushrooms that uses AI to generate answers OR it's a user that tries to do the same. When you read the answers it's clear that most miss a basic understanding of the question and thus generates flawed answers. Answers are either incorrect, incomplete, obsolete, or multiple of those. Unfortunately it also pollutes the forum with a bunch of nonsense.
[Jan 24, 2025, 6:22:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
I'm sorry you think that. I just want to help people make things as easy as possible. I'm one of the people who are responsible for Sweet Home 3D being what it is today. I started working with Emmanuel 15 years ago, so I have enough experience to maybe help someone. I've been looking through the posts on the forum and have seen all kinds of problems that users have, as well as all kinds of answers to questions that always complicate things. Mostly based on Sweet Home 3D, I created Optical Shop 3D and all my requirements for what the program should have in order to be a decent program to use. All the upgrades that I requested are now available to everyone in Sweet Home 3D. Sweet Home 3D is not perfect software, but it now has everything you need to do a project related to architecture and space design. From object manipulation, lighting, measurements, basic rendering, top plans and wall plans with measurements, prices per object, and a total cost estimate. I took a little while to write, mostly I'm sorry that you misinterpreted my responses to people and my intention to help them.
[Jan 31, 2025, 4:32:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
