Total posts in this thread: 2
Previous Thread This topic has been viewed 3100 times and has 1 reply Next Thread
mga56grg
reconnect split walls
Is it possible to reconnect walls that have been split, or were originally created individually?
[May 12, 2011, 4:03:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: reconnect split walls
Marshall,
1 - Connect two walls
If you install the AdvancedEdit plug-in (see manual PDF) you can connect two walls, giving them an "elastic" connection. Corners will be closed, and if necessary beveled.
2 - (Re-)Connect split walls
A split wall is still connected (see 1). You cannot make one continuous wall from two wall sections. Once a wall is split, it cannot be re-joined.
[May 12, 2011, 4:27:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
