Re: Problems by overlaying an object in another
Yuki,
Of course you could also follow the roof tutorial (pdf). Make a wall the size of your counter top, insert an invisible box for the hole, then use CopyAsNewFurniture (pdf), and export the part. While importing you rotate it 90 degrees, and you can use it as a counter top with a hole for the sink.
[Apr 1, 2011, 9:38:29 PM]
[Link]
