Previous Thread This topic has been viewed 3451 times and has 2 replies Next Thread
gdhall
Can't see anything on my floor plan!
Hello, I have no idea what happened? I spent 4 hours designing this clinic for a management project and had just a few things left to do with it and it disappeared. Please help! I can email anyone the file if they have an idea? I can't figure out anything. If I open another file it works fine.
[Mar 30, 2011, 7:33:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can't see anything on my floor plan!
Daryl,
If you send me the file, I'll look at it. However, I can't promise I can rescue your plan.
Did you enable the Autorecover function? (see: File --> Preferences) In that case, when starting SH3D again, it should load the file you were working on. Otherwise, check the appropriate directory to see if there is a work file:
- under Windows Vista / 7 --> C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\work
- under Windows XP and previous versions of Windows --> C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D\work
- under Mac OS X --> Library/Application Support/eTeks/Sweet Home 3D/work
- under Linux --> .eteks/sweethome3d/work
[Mar 30, 2011, 9:59:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
From my past experience, a 2D plan that completely disappears or appears as blank (rulers included) is due to internal computing error, and the file where this kind of error happened can be recovered only by changing temporarily the program.
Recently, I discovered this may happen when you import a DAE 3D model with no thickness. I'll fix that in the next version.
[Mar 31, 2011, 12:00:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
