Re: Cut out
Import the invisible box selecting the Door or window option during the 3rd step, and use one or more boxes of this kind to cut any wall or group of walls (it will cut only walls). See also this discussion.
Re: Cut out
Mic,
Maybe this invisible hatch will solve your problem? And eh, don't forget to check Door/Window while importing, or it won't insert itself in the wall.
---------------------------------------- hatch invisible.zip
(1305 bytes)
(Download count: 4212)
[Edit 1 times,
last edit by hansmex at Feb 11, 2011, 8:20:30 PM]
Re: Cut out
Now it works basically.
check Door/Window while importing... was my mistake, thx for the hint
Problem is, I need an invisible wall/box or whatever which can make an angle on the top. Same system as normal wall have...sloping wall. Is this possible?
Re: Cut out
Mic,
Maybe you can apply a transparent texture to (a part of) the wall? It will show up as black in the design, but will be invisible when you make a photo render.
(1993 bytes)
(Download count: 6837)
Nepal
Re: Cut out
Are you trying to do something like this???? Design created by Macfrog
