Nepal
Re: My apartment in 3D
Hans, I have been thinking of asking a question for some thing that is in the first to pictures here aslo but had no time to share images i also end up getting black dots like the one in first and 2nd pictures sometimes.think its a bug ??? whats your opinion
@ wrosun @ tsukasa
There's not much information on black spots in the forum. - This link describes a problem with black spots, but there are far more black spots than the few spots in the pictures above. - This link also describes a problem with black spots, but unfortunately the picture is gone, so it's hard to guess what the problem was.
There are a few things worth exploring: - which version of SH3D was used? V3.0 or an older one? - which renderer was used? The built-in renderer or the "old" AdvancedRendering plug-in? - if you move the model(s) a bit, do the black spots disappear? It looks as if there is a connection between the window and the vertical stripes...
Nepal
may be you are right because i dont get this problem that often ...i use v 3.0 and use built in photo creation after the floor texture missing problem that was stuck to my head for months i left using advanced rendering....i did not try things you said intensionally but managed to remove those doing things here and there....
Hum, wrosum, don't you over exaggerate a little? Version 3 is even not two months old! May I recall everybody that the rendering at the two best quality levels is done with SunFlow, a nice rendering engine that I didn't program. So, even if time after time, I master it better and better, there are still small bugs that I can't fix easily.
TUNISIE
- which version of SH3D was used? V3.0 or an older one? *I'm using le V3 - which renderer was used? The built-in renderer or the "old" AdvancedRendering plug-in? *built in render - if you move the model(s) a bit, do the black spots disappear? It looks as if there is a connection between the window and the vertical stripes... *Yeah by moving the model they dissappear. *The dots appears only when i use the best quality rending.
Nepal
@puybaret haha may be i over exaggerated ..but the thing is dat i just finished my semester end exams and was in too much pressure so thought it was months ago....what i was trying to say was that after the floor texture missing problems in advanced rendering now i use built in photo creation for the question from hans
These images are RIDICULOUS! I've just downloaded the software (for the second time I guess... the interface looks familiar) and I had no idea renderings could turn out so well. Hope mine look as good when I get going.
