how do I add texture to bottom half of walls?
Im a newbie, and simply want to load tiles on half of the walls in side a bathroom eg say 1200mm up the wall of one wall, or even apply a feature texture tile 3 quarters the way up the wall.
yet it seems only to give option of applying textures to the full wall? I thought maybe adding a new slim wall in front of the main wall of the bathroom, at say the thickness of a real tile then applying that texture, but thought there might be easier methods, as when you make those walls too thin there hard to move round accurately.
Re: how do I add texture to bottom half of walls?
Jared,
There are several ways to do this.
1 - Using the plug-in CopyAsNewFurniture - Draw the walls of your room - Copy the four walls to a different location for each of the colours or textures you want to use - Give the first set of walls the height of the lowest colour, then apply that colour or texture - Repeat the process for the second (and third, etc) part of your design on the second (and third) set of walls - Select the second part and copy it using Tools --> Copy as new Furniture - Paste the copy into your design, change its elevation and place it exactly on top of your first set of walls - Repeat for more colours or textures NOTE: This way left and right side of the wall may have different aspects
2 - Using insertable boxes - Take a standard box and export it using 3D view --> Export to OBJ format - Import it again making sure you check the checkbox Door/Window - Apply the colour or texture you desire to the box, and give it the desired height and width, as well as the correct elevation - Insert the box into your wall - Repeat for more colours/textures NOTE: This way both sides of the wall look the same
3 - Using an imported texture - Use a graphics program like The Gimp to make the desired texture for the full height of your wall - Import the texture and apply it to your wall NOTE: This way both sides of the wall may have different aspects
4 - Read this tutorial for another way NOTE: This way both sides of the wall may have different aspects
Good luck!
