lights question
I have a question about using the lights in SH3D 3.0: When I render the scene (using the Best or next to Best setting) There is now a huge light/white spot on the ceiling. I used the Halogen light (the same light that was used for the beta tests) and have it set to 25% power. I hadn't noticed the spot on the ceiling caused by the light before. Is that a new problem? I'll have to play around with the other lights to see if that still happens.
I'll attach a rendered pic to show you.
(199559 bytes)
(Download count: 812981)
(Notice strong light on ceiling. I have even lowered it so that it's not right up against the ceiling.)
Re: lights question
Wouldn't you have forgotten to unselect Add ceiling lights check box?
Re: lights question
pencilart,
Indeed, lights tend to show bright white spots on ceilings, especially if the light is placed closed to the ceiling. There are a few things you can do: - place the light lower, obviously; - make the light larger, so that it seems softer; - make your ceiling (and walls) Matte so that the bright spot is not, or less, visible.
Re: lights question
ok, I'll try those things. Thanks!
Edit: the light is now 4 feet 6 inches (I guess that means from the floor?) the ceiling was already set to matt the light is now huge, lol, but it does now look softer.
(188194 bytes)
(Download count: 816431)
(light is now 4 foot 1 inch wide and 4 feet in depth.)
[Edit 1 times,
last edit by pencilart at Jan 5, 2011, 7:04:07 PM]
Re: lights question
hi ppl, this software is awesome, i really thank and send appreciates to developers, after 2 full days working on user guide and samples i could succesfully create a room scene, i tried lots but just couldnt make sum so i m asking to masters, one of walls just dont change the color, other one (on right) is close to white but the one which is trouble(one left) just dont change color, i tried to add texture by a white wallpaper but it just didnt take the effect again, its always grey, isnt there a way to get together all walls or selected ones to behave together like elevating and CHANGİNG COLOR , wall just dont change the color, may u help,also the frame and curtain have white pixels around, i just couldnt solve that problem after many tries by lights, do u have any advice for that too?? i m making arrangements with ceiling lights!! may u tell me what basicly ceiling lights add? cus in the sample pic below ceiling lights added and one more white are next of white spot(at top of pic,and i know its cus of in the air-area light that pencilart used in his scene),i dunno where it came from..
Re: lights question
Are you sure you changed the right side of the wall? Do you the color or texture change in the 3D view ?
