mass import of objects?
a lot of questions I have today
My question is, if I can like mass import objects into the library. Like for example when I download several (if not all) objects from archibit, do I really need to import every object individually?
Haven't found something with import with the search so I think it's the right place here to ask :)
Re: mass import of objects?
Strider,
No, you don't. Yes, you do.
Download the plug-in tutorial and read the chapter on Library Editor. You still have to import your models one-by-one, but after that you can import the entire library in one go. Another advantage is that you can easily change computers by taking with you that library.
You can import many files at once in Furniture Library Editor. Just select more than one file in the file dialog, or drag and drop all the files you want to import in the editor window.
