Re: Furnitures turn out white colour after selected or imported in the library - HELP
The user's guide says:
To create a video, choose in the 3D view the initial location of the video camera and click on the red button in the video creation pane. Then move in the 3D view to the next location of the video camera and click again on the red button. Repeat these steps for each location where the camera should pass by during the video. Each time you click on the red button, a new point is added in the video creation pane to show you the path of the camera. As Sweet Home 3D takes also into account the vertical elevation of the camera, its 2 rotation angles and its field of view, you may create all kind of animations. Once the path you created is satisfying, click on the Create button to start the computing of the video frames, then once this computing is finished, click on the Save... button to save the video in a Quicktime file. How can you conclude from this text that you should click first on the Create button then on the red button???
[Jan 4, 2011, 2:37:31 PM]
[Link]
