Total posts in this thread: 1
Previous Thread This topic has been viewed 9466 times and has 0 replies Next Thread
Transparent walls
Hello all smile
Here is a useful trick if you want to apply your company logo to the window(s) of your office or restaurant.
First you need to import two images as textures:
1 - a partially transparent image (GIF or PNG)
2 - a completely transparent image (GIF or PNG)
Attach texture 1 to one side, texture 2 to the other side of your wall. In the preview this will show up as a black wall, because the standard render engine can't handle transparency. But if you make a photo in one the two highest settings, your wall will show transparent. If the logo is displayed mirrored, you can use Reverse walls direction to correct it.
The transparency is maintained correctly, meaning that you can use the CopyAsNewFurniture plug-in or Export to OBJ format and import your model as furniture.
Attachment empty transparent.gif (1993 bytes) (Download count: 17779)
[Dec 11, 2010, 3:11:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
