Advanced render problem
Hi All I have a problem with the advanced render plug in v1.6. I am trying to build a kitchen. When i Import 3d models (mainly from Sketchup) the cabinet models look ok in 3d view and low quality render but when I choose Tools Create advanced photo, the photo will not render correctly. The image is created but some areas of textured objects (ie wooden cabinets) and handles are incorrect. Basically when there is a metal handle it comes out wooden coloured. This changes every time i re-render- ie pressing create sometimes renders some cabinets ok and others wrong. This changes every time but I never get them all correct. Am I doing something wrong? Lower quality renders seem ok? Thanks
Re: Advanced render problem
Sure here the link - its just a basic room at the moment to try and get around the problem. The 2 types of cabinet look ok until rendered on best setting with advanced render 1.6 (on my pc anyway)
I fully suspect I am maybe either exporting the models with incorrect settings in Sketchup OR using the wrong settings in SH3D. Thanks very much for taking a look Hans
Crafty,
Both models rendered correctly in v2.6 and v3.0, except the left-most door of the right cabinet: its centre panel stays grayish.
The problem clearly lies with your model(s). At 2.3 Mb your file is FAR too big for two simple cabinets. When I applied a texture of my own (that never causes problems), I noticed that the surface of the right cabinet is divided into postage stamp-sized squares.
I saw it's a DAE model, and these are known to cause problems every now and then. Try the same design with cabinets from the standard SH3D library. If you want to keep the texture, you can easily extract it from the SH3D file.
Hi Hans I have tried the same model with standard cabinets from the sh3d library and everything works fine - its just the dae models I suppose. Is it possible to change the texture of just the cabinet doors from the sh3d model ie not the whole colour/texture, just the doors. I treid to change colour/texture but it changes the whole object, handles included. Thanks
Crafty... When you use Sketch, make sure you try to texture both sides of the model. If you select an area of your model, right click, and select reverse face to apply the same texture to both sides of the face. DAE models are always 2 sided, and this can cause problems with SH3D. I hope this helps.
For export file Collada (dae) Sketchup:
1 - in options, disable export faces both sides. 2 - Enable triangulate the faces (heavier, but avoids the problem of mesh). Enable export veneer textures; normal!
3 - before export, pass the display model in monochrome. 4 - The visible faces must be white. The faces gray that are invisible , and will not be exported. It is therefore necessary to reverse the gray faces visible that are on the faces of the model. (There are several plugins that do that very well).
