Total posts in this thread: 8
Previous Thread This topic has been viewed 3863 times and has 7 replies Next Thread
Shadowfirebird
An old room with weird corners
I'm trying to create a plan for an old room in which the corners are not at 90 degrees.
I had hoped that I could just enter the wall lengths and then drag them around until the room was right in the program - but when you drag a wall it changes the length, so that doesn't work.
Has anyone got any ideas on how I can measure the angles of my room so that I can enter them in the program?
Or, a way of using the program so that I don't have to measure the angles?
[Oct 10, 2010, 9:53:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: An old room with weird corners
Shadow,
1 - Use a bevel protractor to directly measure the angle of your corners. You can make one yourself using a regular protractor and a ruler.
2 - Using paper or cardboard, make molds of every corner. Then use a protractor to measure the angle.
3 - Locate building plans and use them as a background image.
[Oct 10, 2010, 11:22:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shadowfirebird
That's brilliant, thanks! I'll see if I can buy or make a bevel protractor -- I see plenty of pictures on google.
As for the building plans, if I had some, I wouldn't need to use the program...
[Oct 10, 2010, 1:07:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shadowfirebird
That's interesting. I've just found the plans, not for the room as it is now, but for the modifications the last owners had planned.
Those plans contain neither corner angles nor dimensions.
[Oct 10, 2010, 1:17:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shadowfirebird
update: I bought something similar to this and while it works brilliantly for measuring outside angles, it fails at measuring inside angles like the corner of a room.
The problem is that you can't get it into the corner; one of the two "feet" on the protractor stops you. So, buy carefully.
[Oct 10, 2010, 4:11:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shadowfirebird
I had an inspiration. I think I may have a different solution, if you have a scientific calculator.
1) Measure the same distance out from the corner on both sides. Call that distance a.
2) now measure the distance between those two points. Call that distance b.
3) calculate (2a^2 - b^2) / 2a^2
4) push your cos^-1 button (arc-cos). The result should be the angle. I think.
[Oct 10, 2010, 5:04:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shadowfirebird, your idea is on the right track, but there's an easier formula.
From the following schema:
A sin(α/2) = B/2
α = 2 arcsin(B/2A)
[Oct 10, 2010, 7:51:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shadowfirebird
Of course! Thank you!
[Oct 10, 2010, 9:45:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
