Re: Sweet Home 3D 3.0
When I opened this beta version, 4 recovered files came up. I just closed the first 3 that I didn't want then I kept the one open that I wanted to work with. Will it be doing this by default when you first start it up? The files it recovered were, I think, simply closed because I was done with them.
I played with the lights some more and found that I was able to turn on the already existing lights. Anyway, it's much better looking now.
Nice work Emmanuel!
(357461 bytes)
(Download count: 37305)
(kitchen with new lights)
(167380 bytes)
(Download count: 333021)
(176281 bytes)
(Download count: 36404)
[Edit 3 times,
last edit by pencilart at Nov 18, 2010, 3:30:32 PM]
Well, I'm super-eager to try the 3.0 beta, but I can't seem to install it. Java Web Start loads it, but always ends with the error: "Unable to launch the application." Uninstalling through the Java console and reinstalling does no good.
SW3D v2.6 still runs (and uninstalls and reinstalls) correctly.
Is there any particular information about the error detail or my system that you might need to pinpoint the problem?
timcurran, maybe you have a problem with your installed version of Java. Sweet Home 3D version 2.6 could work independently if you install it from its installer since the installer provides an internal dump of Java. On what system do you work?
Puybaret, I have the same error as timcurran. After install or when try to run installed aplication I get error (see image). My friend has also the same problem.
System: Windows XP x86
Click to Details -> Exception tab
java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.eteks.sweethome3d.SweetHome3DJavaWebStartBootstrap.main(Unknown Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.sun.javaws.Launcher.executeApplication(Unknown Source) at com.sun.javaws.Launcher.executeMainClass(Unknown Source) at com.sun.javaws.Launcher.doLaunchApp(Unknown Source) at com.sun.javaws.Launcher.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.eteks.sweethome3d.SweetHome3DBootstrap.main(Unknown Source) ... 14 more Caused by: java.lang.NullPointerException at java.util.Arrays.sort(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$AutoSaveManager.readRecoveredHomes(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$AutoSaveManager.<init>(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$AutoSaveManager.<init>(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source) ... 19 more
Thank you for this log. I fixed this bug yesterday but didn't realize it could prevent the program from running for users who never tried the beta. I just released the beta 17 that contains the fix of this bug and other minor ones. It contains also updated Czech and Polish versions.
