Total posts in this thread: 135
Posts: 135   Pages: 14   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 348929 times and has 134 replies Next Thread
db4tech
Re: Sweet Home 3D 3.0
Emmanuel,
Thanks for the update!
Still experiencing the same problem with beta 10, plus the ambient lighting is; lets say, a little too bright! wink
db4tech
[Oct 11, 2010, 8:56:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I know, but I have no idea where the problem might come from at this moment...
I was afraid some users find it too dark... Note that if you don't like, you can choose a night hour to turn it off.
By the way did you see that the ambient color is a complementary color to sun color? I hope my way of computing is ok (I computed the average of the other RGB components for each component, see here). wink
Thank you for your feedback.
[Oct 11, 2010, 9:28:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I updated the current Beta to improve silk rendering / Uber shader. It goes 4 times faster and renders better. smile
[Oct 12, 2010, 12:42:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours
[Google translate]
Some bugs on my side,
Renderer SH3D (Java3D) version 2.6:
Renderer SH3D (Java3D) version 3.0 beta 11
This is a 3 part construction:
- Stage 1 is in the file
- Stage 2 with imported plugin 'Copy as new furniture'
- Roofing made in SketchUp and imported furniture.
In version 2.6, the textures of the walls are all identical, unlike the version 3 beta 11, which displays a color difference between stage 1 and the other 2 floors.
Surprisingly, rendering him sunflow is correct in the beta 3.
Another bug reported:
white marks on the curtains, palm tree, and a strange reflection on the TV, not present with Advanced Rendering Mini v1.6.1
[Note from moderator]
Fixed link to images, and removed French translation.
Please, avoid translations. This is the English part of the forum.
If you don't speak good English, it's not a problem, you're not the alone person in that case. wink
[Oct 12, 2010, 6:17:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tonight, the Beta 12 brings the ability to store the current point of view and restore it later, as proposed in this thread.
@PtiNounours
Wouldn't have you check "shiny" on outside part of your walls?
By the way, nice model! smile
White marks or spots are not really a bug. It's a shininess effect that appears with the silk rendering used now at the best quality level. Miserably, many models (like curtains) use a very high shininess level when they shouldn't, that's why I'll add a Matt / Shiny choice on furniture in a coming version... or maybe I'm wrong to keep trying the silk rendering/Uber shader.
[Oct 12, 2010, 8:48:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours
For rendering sunflow Version 3 beta 11, the result is rather convincing. Particularly in terms of lighting for interiors that is much brighter without having to add many light sources that was not the case with the Mini Advanced Rendering v1.6.1 which could sometimes works really dark.
Conversely, there are actually bug graphics on objects that have bright textures. I would do more tests later.
On the walls, they are all set to 'Mat'. I think this setting does not affect rendering SH3D (3D view), but acts only on the rendering Sunflow?
When I created a textured object in sketchup then imported into SH3D version 2.6, no color differences were noticeable with another object that both created and textured in SH3D. It seems to me that under the version 3 beta 7 or 8, I did not this difference in color, which appeared to me since this latest version. (I zap versions 9 to 10 that I have not tested).
[Oct 12, 2010, 9:59:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Setting walls rendering to shiny has some effect in the 3D view too (turn the wall or the camera and you should see it).
If ever you can send me your SH3D file or at least a part of it showing the problem, it will help me to find the bug or the reason of the behavior change.
[Oct 12, 2010, 11:25:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours
I send you a test of a wall with texture. Not knowing how to deposit the file on the forum, I send you by easy-share link:
http://www.easy-share.com/1912613178/eTeks_test_texture_wall.zip
comprenant:
- File-SH3D
- Dae files and sketchup
- Texture0-(wall)
- photos
I created with the same texture as a wall and then imported into sketchup SH3D and create a wall directly under SH3D.
Results for rendering 3D View of SH3D:
v2.6 no difference in staining
v3 beta11 SH3D wall (the right) is more clear
This difference also comes with copying objects with the plugin 'copy as new furniture', since version 2.6 and open with the version 3 beta 11.
Results for rendering Sunflow ok in V3 beta11.
[Oct 13, 2010, 12:15:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sebastien,
EasyShare? First I have to wait for a button, then I have to wait even longer, than a Captcha... Then it didn't work and now I have to wait at least 15 minutes longer... In my book that's DifficultShare! devilish
Why don't you try www.mediafire.com ? Fast, no waiting, you can link pictures directly to the forum, nice interface. THAT is easy share!
[Oct 13, 2010, 12:48:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours
Up mediafire:
http://www.mediafire.com/file/aqj9sbkm3fbjyka/eTeks_test_texture_wall.zip
'DifficultShare' laughing I really laughed; excellent Mediafire
[Oct 13, 2010, 4:06:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
