Re: Sweet Home 3D 3.0
sgabu77, please change the shininess to matt on your object, and tell us how it worked. Note that the quality 3 and the quality 4 don't use the same SunFlow shaders and may render objects quite differently.
Good evening guys. I did several tests with my textures, and I noticed that the problem occurs at random with different textures and different files. I think, but I do not know if it is possible that the advanced rendering 1.6.1 is not fully integrated with the new version.
The parameters set in the Advanced rendering plug-in won't be copied back to Sweet Home 3D v3. Set North direction to 90°, date to 1st september, hour to 13:00, remove ceiling lights, and you will have the same results as the image you joined in your linked file.
Hope this was what you were looking for.
