Total posts in this thread: 15
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 7156 times and has 14 replies Next Thread
Rob123
Color of walls: problem
Hello all,
2 walls defined with the same color (identical color code / H:40, S:25, B:85) do not appear identical. The color chosen for both walls is brown. However one wall appears as light brown and the other wall appears as dark brown.
How can this be fixed ?
Thanks in advance.
Robert
[Sep 5, 2010, 8:52:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
db4tech
Re: Color of walls: problem
Hi Robert,
Welcome to the Sweet Home forum.
If possible can you show a picture of what you mean?
Do you mean when the scene is rendered, or the 3D view (bottom right)?
If you mean the 3D view, then different shades are used to help represent a 3D environment, when the scene is rendered, all colours should appear as they would in real life, only changing in lightness, depending on how the walls are illuminated, by lights placed in the scene.
db4tech
[Sep 6, 2010, 2:18:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hampi
In the begining i also was confused in the 3D view. I put a white wall but it doesn't appear white... but make sense.. Important is only, that in the rendered picture it will have the right color.. and with the advanced picture there is a great option for rendering.
[Sep 6, 2010, 4:00:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The color of walls is different depending on their orientation towards the default lights set in the 3D view.
[Sep 6, 2010, 6:27:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rob123
Hello all,
I would like to display an image to illustrate what I mean.
Can I attach or load an image somewhere ?
Robert
[Sep 6, 2010, 8:40:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rob123:
You can use www.mediafire.com or a similar service to upload your picture. Copy the URL of the picture and paste it here using the Image button.
[Sep 6, 2010, 9:17:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rob123
Hello all,
Please see the attached picture to illustrate what I mean
(hope I have managed to load the picture - using Mediafire).
2 walls defined with an identical color code appear in a different way (see wall with the door versus wall with desk + tv). Please also see the wall with fire place (H:40, S;25, B75) which however looks very similar to the other walls defined as H:40, S;25, B85.
Does this depend on the lighting, orietation of the wall, .. ?
Thank you in advance for your input.
Robert
[Sep 6, 2010, 9:48:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rob123
<a href="http://www.mediafire.com/imageview.php?quickk...l1kxns1&thumb=5" target="_blank"><img src="http://www.mediafire.com/imgbnc.php/4b8fdf622...72660f3ba92eb4g.jpg" border="0" alt="Unlimited Free Image and File Hosting at MediaFire"></a>
[Sep 6, 2010, 9:51:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
whippetsleek
Maybe it is just my monitor, but that picture looks like a normal 3d view with shadowing to give the view depth. Have you tried taking a photo with the create photo option under the 3dmenu? If you take a picture, and the walls still look an off color, then it might be a problem, but I think from your picture that is just normal shading.
[Sep 7, 2010, 2:10:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rob123
I created 2 pictures using 3D View.
1/ 'High quality'
http://www.mediafire.com/i/?6vi1x12jwccvdpv
The room appears very dark and the walls transparent.
Is this normal ?
2/ 'Fast create'
http://www.mediafire.com/i/?dedjix8aqhw6n3s
In this case 2 walls defined with the same color code appear as light brown or dark brown. The difference in shading is according to me much too big.
Am I doing something wrong, might I have misunderstood something ?
[Sep 8, 2010, 8:18:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
