Total posts in this thread: 2
Previous Thread This topic has been viewed 3157 times and has 1 reply Next Thread
jdjigar
india
How to make a wall fixed ? Urgent help needed
Hello Developers,
We need support to understand how to make a wall in 2D design fixed.
This means we need to select a element and only make that wall as fixed.
For now we have a option under PLAN to lock a plan. We need similar feature for a single WALL ONLY.
Please reply its urgent.
[Jul 27, 2010, 1:58:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to make a wall fixed ? Urgent help needed
jdjigar:
SH3D is free, open source software. This forum is run by volunteers. If you have urgent problems, I'm sure the developer will be glad to make you a proposal for 24/7 software support.
The feature you request is not available: you can freeze all walls and rooms, or none at all. But, since this is open source, you are free to modify the software to include this feature.
As a workaround you could import a background image that clearly marks the spot of your fixed wall, so that you have a constant reminder of its place. You could then use a box to make the wall. Making the box/ wall (temporarily) invisible would prevent you to change the placing of that object.
Hansmex
[Jul 27, 2010, 5:00:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
